Need Oil Catch Can Help!!!
Old Jun 2, 2005 | 08:59 AM
DUROEVO's Avatar
Question Need Oil Catch Can Help!!!
Hey guys I got the Greddy oil catch can lastnight and I cant find a freakin place to put it.....Want to avoid mini battery......Can anyone help with some ideas and PICS? Thanks
Old Jun 2, 2005 | 09:06 AM
Kronik's Avatar
Well I just put in my Ralliart OCC -- I wound up putting it right under the intake. Granted I no longer have the stock intake. I know a lot of people have been mounting theirs right near the dipstick...
Old Jun 2, 2005 | 04:46 PM
DUROEVO's Avatar
Bump!!
Old Jun 2, 2005 | 04:52 PM
Cajun Power's Avatar
I have mine behind the battery. I had to pull the strut bace and use a bolt off the master cylendar and make a bracket to fit. Now I am running into problems with the hoses getting kinked between the battery and the inlet/outlet nipples.
Annother option is to get a 1" x 36" x 1/4" alum strip from home depot or lowes and bend an upside down u and on the passanger side to the left of the dip stick there is a bolt on the inside on the fender that is kinda horizontal and you bolt the u there and the the can on the other side of the u. This works much better. The lines dont kink as badd cuz you can run them straight in and out.
Oh yea. We have the square Helix can but I assume the greddy are about the same size.
Hope this helps.
Old Jun 2, 2005 | 04:59 PM
smokey's Avatar
I put mine in the same place as cajun power. See the attached picture. It's a real tight fit, but it fits. YOu have to remove the strut bar and I used the bracket that they gave me. I just put the bracket at an agle and attached the can to the bracket. Let me know if you have any questions.
Old Jun 2, 2005 | 05:02 PM
tke_413's Avatar
Lol, just get a mini-battery...it fits SOOO much better!
