balancing and blueprinting block
Old Jun 2, 2005 | 12:05 PM
vrrrm...psss's Avatar
Hey guys, does anyone know what exactly is involved in this process?
Old Jun 2, 2005 | 01:33 PM
1.8t's Avatar
Blancing the rotating assembly is just matching piston weight across the board along and matching rod weight across the board. There should be a spot on both where material can be removed by the machine shop to drop a gram or so. It all depends on how high quality the parts are as to how far out they will be.
Old Jun 2, 2005 | 02:17 PM
BlackEVO's Avatar
Don't forget the rods, crankshaft, flywheel and clutch. The pressure plate should be indexed to the flywheel for balancing.
Blueprinting generally means cleaning, measuring, machining and matching *everything* in the engine to *exact* specs/tolerances. Most of this is stuff you would (should) do during a normal rebuild, but to the Nth degree of detail and completeness using precision measuring tools.
Old Jun 2, 2005 | 02:20 PM
Darwinian's Avatar
The tolerances for the bearings should also be checked with plastiguage. It is also a good idea to get stuff magnafluxed to check for inherent weakness and cracks in rods and such.
Old Jun 2, 2005 | 02:36 PM
interesting.....I was just curious as to what takes place in the process....sounds like fun haha
