Question!! - A/C Issues!!
Old Jun 12, 2005 | 08:56 PM
evo8tp's Avatar
my car stalls out so much with the ac i dont even use it
Old Jun 12, 2005 | 09:01 PM
EvoLoverForever's Avatar
Originally Posted by mrbkkt1
mine actually doesn't jump or go down @ all- first car that i have had that doesn't have this . maybe ac clutch is worn?, thats why driving hard w/ ac on isn't good, undue wear on clutch.
maybe cause yours is 05... these guys have an 03
Old Jun 12, 2005 | 09:06 PM
mifesto's Avatar
try a grounding kit... as it will increase your idle volts...
Old Jun 13, 2005 | 06:13 AM
DrBump471's Avatar
I do have a grounding kit (Lineage)!! I am going to change the spark plugs this weekend and see what happens.
OUCH!!?? yours actually stalls out? ugh
Old Jun 24, 2005 | 02:24 PM
2ggst's Avatar
has anyone noticed, after the cam install it won't idle with the ac on? i just did some cams and when the ac is on the car dies down. when i'm actually on the throttle it's fine. i don't know if it's just my tune or what. right now, it's not tuned for the cams. my ecu will be getting sent out soon to get reflashed for the new mods.
Old Jun 24, 2005 | 04:08 PM
gapecans's Avatar
I was embaressed to run my A/C last summer in Middle GA. The humidity is intense. Had a mail-in Dynoflash last Dec and the AC issues this summer are cured. The load effect of the A/C is minimal now. Al knows.....................
Old Jun 24, 2005 | 04:56 PM
DrBump471's Avatar
well I changed my spark plugs last weekend and things a little better. I may have had some fouled plugs. Not perfect but definately better.
gapecans - did you have a custom tune or flash??
Old Jun 24, 2005 | 05:58 PM
althemean's Avatar
There has to be some kind of relay solenoid or something that tells the car to increase RPM when the A/C is activated.
Any auto mechanics here?? This is something that all cars should have.
My 05 does the same crap at idle, feels like its gonna stall on really hot days, were talkin 100+ in the desert. Also, my turbo timer builds up like mad...what would normally be 45 sec to a min ends up being 2 min with the a/c on. It never counts down at stop lights.
Old Jun 24, 2005 | 06:10 PM
TRDHarrier's Avatar
try using a ground kit. it worked better for me. only a liuttle bit
Old Jun 24, 2005 | 07:08 PM
DrBump471's Avatar
grounding kit already installed
Old Jun 24, 2005 | 07:14 PM
1BADASSEVO8's Avatar
Its call the ISC( Idle Speed Controller), I am having this same problem on my evo8 but i also have an AEM. This also happens on my 4G63 Turbo Eclipse. I am fiddling with settings on it. The cool thing about the AEM is that you can't even tell i have HKS 272's.
Old Jun 24, 2005 | 07:16 PM
4Gsixty3's Avatar
grounding kit definately helps + changing the plugs fixed my idle problem this summer! it only happens when i first turn on the A/C when idle, after few mins of driving everything were back to normal.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
Darewood
Apr 20, 2011 03:26 AM
joedr
Aug 22, 2008 01:11 PM
