Running rich
Old Jun 11, 2005 | 11:06 PM
an0ther's Avatar
Running rich
It seems that when I reset my computer my car seems a little faster till after a few days. It runs richer and seems to start to get sluggish at low rpms but still pulls hard. It will shoot flames at high rpm shifts. Is there something that is causing this or is it just normal for the computer to get richer as it learns the car?
My mods are
base dyno flash, turboxs 3" tbe with cat del, hallman evo rx mbc at 20 psi, koyo radiator
Old Jun 11, 2005 | 11:16 PM
EVO_JOE's Avatar
I think you need to get your car tuned
or if you did get it tuned go to a different tuner
Old Jun 11, 2005 | 11:26 PM
an0ther's Avatar
I have just the mail in flash, but it seemed this way before I had the flash.
Old Jun 11, 2005 | 11:27 PM
an0ther's Avatar
would spacers on the cat o2 sensor cause anything? Could this cause the car to run rich because it cant read enough? I have 2 of the 18mm antifoul spark plug adapters spacing out my o2.
Old Jun 12, 2005 | 07:03 AM
an0ther's Avatar
bump, anyone else have any opinions/suggestions?
Old Jun 12, 2005 | 08:37 AM
mooreboost's Avatar
No, the o2 sensor only has an effect on the cars idle.
And the antifoulers do not have an effect on the readings at idle either. I have them installed and I still idle at a 14.5-15.2 AFR.
Old Jun 12, 2005 | 10:44 AM
an0ther's Avatar
guess i just need to get an afr gauge but man their expensive.
Old Jun 12, 2005 | 12:41 PM
Blue Oompa's Avatar
i thought that the evos ran rich from the factory for some reason but i dont have one so i dont know?
Old Jun 12, 2005 | 12:43 PM
UT_Evo's Avatar
They run way rich from the factory. Usually around 8.8:1
Old Jun 12, 2005 | 12:52 PM
Blue Oompa's Avatar
how do you read the afr readings? what does all the numbers mean and what is a good mixture?
Old Jun 12, 2005 | 01:19 PM
djmikeymike's Avatar
with the EVo under boost you want to be around 11.5 to be safe ......N/A cars are different i think they are more like 14 but i could be wrong...
here a a good A/F meter
there is also the LM-1]
and there a a couple more but im done doing your homework
Old Jun 12, 2005 | 03:09 PM
nothere's Avatar
you need a wideband 02. there are a number that are available. I have used the innovate lm 1. they now have a cool gauge. but anyway the wideband will give you an indication of how things are burning.
wot on the evo, depends on the tuner, range from 10.5 (creepy rich) to 11.5. off wot the mix can run leaner up to 14 or 15 (say cruising down the road) idle with regular cams 14.7 is what people shoot for.
trouble is, if you have to ask, you need to know you might burn up your engine trying to tune your engine.
