Is 22psi Ok?
Old Jun 12, 2005 | 07:38 PM
steelcityevo8's Avatar
Is 22psi Ok?
I got a mbc and peaking 22psi of boost falling off about 1 psi or so is that ok on the motor or is it out of the turbos efficiency range? oh hate to sound dumb but 22psi is equal to 1.6 bar correct cause thats what my boost gauge reads
Old Jun 12, 2005 | 07:39 PM
bigmike9726's Avatar
depends on the octane of gas you are using
Old Jun 12, 2005 | 07:40 PM
SEVEN's Avatar
No fuel pump?
Mistasparkle's Avatar
mine goes to 22 and tapers to 20 till redline on 91 octane.
even with 100 octane when i turn up the boost it hits 25 (thats where i set it) and tapers to 20 again.
93+ you should be alright, but not with anything less
Old Jun 12, 2005 | 07:42 PM
usually 94 pump lucky enough to have it around here is 22psi = to 1.6 bar
Old Jun 12, 2005 | 07:59 PM
RazorLab's Avatar
1.6 bar = 23.206038 pounds per square inch
Old Jun 12, 2005 | 08:05 PM
Originally Posted by EVO2QUIK4U
more mods like fuel pump. you'll be able to hit the 22 psi mark but dont want the fuel cut
what u sayin 22 too much without a pump then what u suggest 21 20 19???
Old Jun 12, 2005 | 08:07 PM
djmikeymike's Avatar
this MBC the only mod you have??
Old Jun 12, 2005 | 08:13 PM
http://www.justchil.net/psi2bar.html
Old Jun 12, 2005 | 08:17 PM
SilverMr's Avatar
Dan,the owner of Harman Motive in Torr.Ca.,told me that his MR with a ECUTEC flash peaked @22psi tapering to 20 psi on 91 oct.He said that anything more would be unsafe but that it was perfectly reliable @22psi if tuned correctly.If anybody knows for sure please let me know because I have not done a flash yet but I'm interested.Anyones help would be appreciated.
bigjhoney's Avatar
I run 21 psi all day, no upgraded pump, I got sunoco 94 around here, but I stick with shell 93. I wouldnt run boost like that unless you got basic mods done too, and your tuned. You will barely feel a diff going from 20 to 21 or even 22, its not worth it for the extra psi to be worried.
4Gsixty3's Avatar
damn, i m running 23psi all the time since last year ... hope no damage were done to my car....
Old Jun 12, 2005 | 08:48 PM
no damage can be done unless you start knocking or detonating
i run the 22 on a custom tuned exede
