Question about BCS Boost Control Solenoid Removal
Is there a purpose to the stock BCS or Boost Control Solenoid if you are running a MBC(manual boost controller)? Right now I have it capped off and I only have vaccuum lines running to the MBC and it has been working fine. Is there any reason why I can't just remove the BCS from the car completely?
In 1G/2G DSM's I removed this piece with no problems once I correctlty installed a MBC. I had no side affects after doing this.
Thanks in advance.
Thanks in advance.
Originally Posted by Joe's_EVO8
What was the code if you recall and could you feel any difference in the car?
