SAFC with flash ecu
Old Jun 14, 2005 | 12:55 PM
honda-guy's Avatar
SAFC with flash ecu
the car was dyno tuned and flash by turbotrix. i'll be installing megan racing manifold and O2 housing soon and some cams in the future. i want to install a SAFC to adjust fuel incase the manifold and O2 housing change the air/fuel ratio. will i have problem runing the SAFC with the flash ecu or should i get the ecu reflash to stock map first.
Old Jun 14, 2005 | 12:57 PM
Warrtalon's Avatar
This goes in the Tuning forum, and a search gleans your answer.
Yes, an S-AFC on top of a flash is very useful as it allows you to fine-tune your AFR beyond the static setting of the flash.
