UR high flow CAT
Old Jun 28, 2005 | 07:33 AM
Nemesis3's Avatar
UR high flow CAT
Anyone with a Ultimate Racing 3" HF CAT:
I just installed a Espelir 3" DP and the UR HFC to Espelir Cat-Back which I had on for a year now. Anyway after finishing I started the car up and checked for leaks around the inlet and outlet connection of the CAT, none was noticed/seen. But I notice a high pitch/raspy sound, guessing from the CAT. Does anyone else notice this or any weird sound?
The car runs great but just curious of what that sound may be and if anyone else noticed it?
Thanks
Old Jun 28, 2005 | 07:41 AM
taenaive's Avatar
I have UR HFC. I don't hear any weired sound. you might have a leak somewhere. I hear more roar when I do WOT.
Old Jun 28, 2005 | 08:22 AM
PVD04's Avatar
Thanks
I had a problem with the cat rattling against the heat shield under the car. It didn't do it at idle, but while revving the engine or driving along it would make a very annoying sound. That could be your problem.
-Paul
Old Jun 28, 2005 | 08:26 AM
Nemesis3's Avatar
Ur
Thanks. I'll check it again for any leaks, but when I did the lighter test it didn't seem to leaking.
Old Jun 28, 2005 | 09:32 AM
mybada's Avatar
Yeah, check for the leak or broken internal.
I've been using UR 3" HFC for about 3-4 months, no CEl, not a single problem
Very good stuff!
Old Jun 28, 2005 | 10:39 AM
ProStreetOnline's Avatar
That sound could very well be an exhaust leak... make sure nothing is leaking... turn the car on, and get under it, and see if you can hear any direct leaks...
Old Jun 28, 2005 | 04:18 PM
Nad1370's Avatar
Been using it for 2 years------no problems.
Old Jun 29, 2005 | 07:23 AM
Nemesis3's Avatar
Dp
Haven't checked it yet, will do it today., but does anyone know if the stock O ring for the DP works or seals properly on a 3" aftermarket DP?
