Tranny Questions
If your clutch is going, when you floor it your clutch will slip causing the rpms to rise without you accelerating and then fall back down and grab...
If your TC was going you would get a loud howling/whine noise from your tranny area ...
If your synchro were going you would constantly grind when you shifted gears ...
Hope that helps ... Happy 4th!
