Oil consumption question
Old Jul 10, 2005 | 03:45 PM
Thegame's Avatar
I know that it's a fairly common problem for some us that our cars consume a lot of oil. After just 400 miles since my last oil change I was down about 1/4 quart. No leaks from the drain plug, filter, etc. I do have an oil catch can and that's not really filling up either. I also know it is acceptable to consume as much as 1 qaurt per 1,000 miles. My question is: Does anybody know the quantity of oil required to move the oil level from the bottom slash on the dipstick to the top slash on the dipstick? I figured it to be around 1/2 quart. I just find this really weird and it could have been dangerous if I wasn't so obsessed with my car maintenance.
Old Jul 10, 2005 | 03:46 PM
kmcconn9's Avatar
thats strange, I dont see any consumption between changes..
Old Jul 10, 2005 | 03:49 PM
Curt@MrLed's Avatar
Former Vendor
1 put a catch can in, 2. some of our cars use a quart every 2000 (<EDIT) mi others dont.. dont forget the more your on it, the more oil you will use, cause it turns into a gas when (blowby) your pushing the car hard..
Old Jul 10, 2005 | 03:51 PM
my3000gt's Avatar
I have never had to put only oil in my car as well.
Old Jul 10, 2005 | 04:34 PM
Jeff_Jeske's Avatar
03 with 20k ..... never adding oil even after a track session.... I beat the snot out of my car....lots of high speed road racing.
Old Jul 10, 2005 | 04:55 PM
Compjoc's Avatar
You might have a problem. I've never had to add oil and im going on 20k.
Old Jul 10, 2005 | 04:57 PM
Thegame's Avatar
Any idea what this can be cause by? I'm surprised nobody has mentioned they've had the same problem yet. Maybe I should have the dealer check it out and do some tests.
Old Jul 10, 2005 | 05:12 PM
blueo4's Avatar
You have a problem if you are loosing oil!
Afterall t aint a honda!
Are you using the Mobil 1 FS? If not stick to it!
Old Jul 10, 2005 | 05:13 PM
PA-silver03evo's Avatar
I go 5k between oil changes and its always at the same level when I change it.
Old Jul 10, 2005 | 05:14 PM
temps's Avatar
it could be... a bad break in period.
I got that off an article i read somewhere. it was posted on this forum. the article mentioned how crucial the breakin period was for the evo. depending on how it was broken in, your evo would guzzle oil or wont.
Old Jul 10, 2005 | 05:18 PM
11secEVO7's Avatar
hmm...i also have a similar problem...
no leaks etc..
but i do have to top up my oil every so often(not much tho)....say monthly..
it's noticeable.
Old Jul 10, 2005 | 05:28 PM
BuLocal's Avatar
I never loose a drop...........maybe it has something to do with the mods.
Old Jul 10, 2005 | 05:32 PM
Thegame's Avatar
I broke my engine in like a complete grandma. My car and I didn't even know we had a turbo and I went to about 1,200 before I slowly started to see what the car had. So break in is out of the question. Had about 12 miles when I bought it. Never used anything other than Mobile 1 10w-30 synthetic. So I guess I better get to the dealer and see what they tell me. I'm going to make an appointment for Thursday, my day off. I'm only slightly modded, so I'm just going to put the stock intake back on. We'll see what they say.
Old Jul 10, 2005 | 07:19 PM
MaxR's Avatar
excessive idling will consume oil. throttle body is closed, high vacuum, oil gets used up. that might be your answer.
Old Jul 10, 2005 | 07:33 PM
money pit's Avatar
My car used a little under a quart in 4500 miles. I took it easy on the break in period as well. Every high-performance car i've owned has done the same.
