defi D series boost gauge help
Old Jul 16, 2005 | 12:49 PM
andyr2971's Avatar
tried installing the gauge and have the vacuum lines all hooked up. the problem is the illumination wiring.
i have my black wire grounded and tried splicing the white wire into the illumination (green/white) but the gauge isn't lighting up...any suggestions?
is that wire ignition? do i have to actually start the car or can i just put hte key in and half turn it?
thanks for the help in advancce!
-andy
Old Jul 16, 2005 | 12:52 PM
Thegame's Avatar
If you're hooked up correctly, you don't need the key to get illumination. All I do is turn on my headlights and the gauges light up. Re-check your wiring and make sure your vampire taps are clamped the whole way down. Also make sure you didn't use one that was too big.
Old Jul 16, 2005 | 01:15 PM
andyr2971's Avatar
yup it was my wiring...bad grounding...thanks for the help!!!
Old Jul 16, 2005 | 03:20 PM
Wicked05's Avatar
....i was just gonna say it was the grounding...
on all electrical...that is usally the culprit....
Old Jul 16, 2005 | 07:32 PM
Jakeg97's Avatar
ground here
