installing the amp in evo
Old Jul 18, 2005 | 10:33 PM
electr0's Avatar
i need help finding where in the firewall can i just put the cable to the battery to the subs.. the amp power cable. where is the easiest and biggest hole that i dont have to drill.
Old Jul 18, 2005 | 10:39 PM
plokivos's Avatar
you could run it through the left bottom side of the driver seat through the fender and back into the engine bay.
Old Jul 18, 2005 | 10:58 PM
AustinEVO's Avatar
Yep, that's what I did, worked out great.
evo_rc's Avatar
theres a hole on the passanger side that has a rubber or plastice thing that fills it up.But if you take the rubber out and run the wire it will come out behind the glove box. I was about to do that but you need more wire since you have the battery on the right side. We found it easier to drill a hole carefully on the driver side .Imo it is much cleaner and you save wire.
