Screeching noise (Evo VIII MR) - please HELP!!
Hi,
Just come back from a little drive. The car (Evo VIII MR) has been absolutely perfect so far....I've done 6000 miles and had it from new.
Got to my drive and had to do a few manoevres to park it properly. While I was parking, I had my foot on the clutch and slowly feeding it out to make small adjustments to my parking. I was going backwards and forwards like this for about a minute. While doing this....a really weird screeching noise was coming from the front of the car. The only way I can describe it....sounded like when the fan belt needed changing in my old vw golf!
Now, I've had the usual groaning noise that a lot of people get when starting the car and pulling off slowly for the first time...this was completely different...very high pitched screeching.
I don't understand what this could be. Can it be the clutch. I have babied the clutch and have not launched once/ I don't ride on it either. Never taken it to a track or dragstrip. I do however live in London so there is a lot of stopping and starting which means I'm on the clutch more than I would be if it were not so busy. If it is from the clutch ....should I worry about it. I don't seem to be getting any slippage when the car is pulling through the gears.
If it isn't the clutch...what else could it be? Should I be worried?
Any help/advice is really appreciated.
Originally Posted by hkfeet
Are you still using the stock advans? Mine makes a loud scrubbing noise at low speed turns in 1st or when Im parking
Originally Posted by MTMS4
Have the dealer check it out; that's what the warranty's for.
your belt for your pump is prob loose, so when you turn the wheel to full lock it slows the pump making the belt squeel if its loose... have you checked that yet, since you know what a squelling belt sounds like...
a belt wont squeel if its loose huh, even while going straight... okay.. and he never said he was just going straight.. usually when people park the turn the wheel..
Yes. You're right, a loose belt will squeal. But I wasn't talking about the belt, I was thinking about the PS pump itself. A bad pump will squeal when the steering wheel is turning. By the way, he did mention he was going striaght if you read carefully on post #6.
I too have noticed this just recently on my 2005 MR. It's during low speed driving combined with tight turning OR just sitting parked with the car on and turning the steering wheel from lock to lock I get a slight squeeling noise like the power steering pump is potentially bad or the belt could be slipping.
I am going to make an appointment to take it into the dealership to have it looked at.
