Buschur Deluxe I/C Kit Fittment?
Old Jul 30, 2005 | 09:26 AM
platinumspecv's Avatar
Hi I currently have the Buschur Deluxe intercooler kit with Upper i/c pipe. Now I had to get the mini-battery kit for this pipe and I want to go back to a bigger battery. This mini battery really blows. So my question is - will any upper i/c pipe work with the Buschur Deluxe fmic kit? Can I buy the HKS upper i/c pipe?
Old Jul 30, 2005 | 09:29 AM
yayson's Avatar
What dont you like about the mini battery? I am thinking about getting one.
Old Jul 30, 2005 | 09:35 AM
Iceman2011's Avatar
helix upper IC works fine as well
Old Jul 30, 2005 | 09:40 AM
althemean's Avatar
+1
Old Jul 30, 2005 | 09:45 AM
superman105's Avatar
Helix IC pipe didn't fit on my car
it was off by 3 inches
I had to cut it up and reweld
Old Jul 30, 2005 | 10:09 AM
Str8Ryda's Avatar
I don't know of any upper that will work with it. Br's piping is set up for ONLY his FMIC but, if you get lucky you might be able to find another pipe set that fits. My friend and I had trouble putting the stock upper on the BR kit.
Don't get the Helix it's actually a DOWN GRADE from stock. The stock one is like 63 mm which is about 2 mm smaller than 2 1/2". The Helix is 2 1/4" thats why it works withe the stock battery.
Have you given any thought to relocation to the trunk? If so check out this thread the RELOCATION for the STOCK BATTERY it's pretty tight!
https://www.evolutionm.net/forums/sh...ighlight=nisei
Good Luck Brother!
Old Jul 30, 2005 | 07:37 PM
damn so basically id have to get a pipe made
Old Jul 30, 2005 | 07:53 PM
VTECH8TR's Avatar
Krunal,
I am with you man, this mini battery sucks. I am always afraid that i will get stuck somewhere. I have been researching our options bro.
Old Jul 30, 2005 | 08:17 PM
marksae's Avatar
I'm not sure where you're getting your information, but I've personally measured my Helix IC pipes w/ a caliper and they're around 2 3/8" OD (60mm), which is the same as the stock IC pipe diameter. The lower IC pipe is where the restriction is at, so the Helix eliminates that.
Old Jul 30, 2005 | 09:15 PM
use2vtec's Avatar
I think any intercooler pipe will work with the Buschur Intercooler. I had the Buschur UIC pipe way before my intercooler and it fit perfect up to my stock intercooler with no fitmest issues at all. Once I bought my intercooler, once again I didnt have to change out or cut anything to make it fit. You could even run your stock UIC piping with that intercooler if you wanted too.
Old Jul 30, 2005 | 09:18 PM
Rollaway's Avatar
the ams upper ic pipe will fit the br fmic.. which is my current setup.. however you will still need to use a smaller battery.. on my previous evo i had stock upper ic pipe fitted to the br fmic for a while
Old Jul 31, 2005 | 04:30 AM
Precision Dyno's Avatar
Why Not relocate the regular battery to the trunk?
Summit sells a NHRA legal complete kit for $72...
Look into it.
Old Jul 31, 2005 | 04:43 AM
awdjunkies's Avatar
Look into it.
how will this affect your weight ratio ??? I remember my BWM had it in the trunk as well
Old Jul 31, 2005 | 08:18 AM
IF I were to get a trunk relocation kit - id ' want a kit with all the wiring. Anything available?
Old Aug 11, 2005 | 02:28 AM
Str8Ryda's Avatar
You should try calling Nisei they just released a relocation kit but, I'm not sure if it comes the wiring though.
Cheers!
