Anyone with JDM MR Headlights help please
I need to raise the passenger side low beam since on the jdm it comes already from the factory aimed too low, therefore, can you please post a picture of the MR headlight from the back and show, how do you adjust the beam pattern, please beware that the adjuster on the USDM is totally different.
Originally Posted by Mr. SUAVE
Can u still adjust the low beam from the switch inside the car with the JDM headlights?
yes, it works, but even at the highest setting, you still needs to raise the passenger side, since they are aimed lower due to been RHD spec.
turn the knob, you come down from the top with a philips... need to do it at night.
measure to the center mark on the headlights in front of the bulbs... park the car on level ground, measure that mark up 20 feet away. thats your line, turn til you get it right, it's not hard, a flashlight should help ya. if you pulled the usdm ones off (not sure what ones you got) you can see where the path to adjust is blocked on the usdm ones )
