plugging boost lines
Old Aug 4, 2005 | 11:28 AM
hawaiievo's Avatar
hey, just wanted to know what you guys have been using to plug boost line when installing your mbc bushcur didnt send me any so what should i use
Old Aug 4, 2005 | 11:42 AM
bolsen's Avatar
You can get vaccum caps at your local auto store.
Old Aug 4, 2005 | 11:45 AM
Warrtalon's Avatar
Since my Hallman came with 2 caps, and I needed 3, I just used one of the caps on the MAF pipe nipple, then I took a small piece of vaccuum hosing about 3-4" long and capped off both BCS nipples by attaching both ends of the small piece of hose. It ends up making a semi-circle where the 2 nipples are basically connected to each other. This is a very simple thing to do if you don't have 3 caps. If you have 0 caps, then you can take another small piece of vaccuum hosing and seal off one end with a screw, nail, or bit of some sort. Stuff whatever you use into one end and either clamp it down or use a zip tie to hold it in place. Then, place the other end of the small vacuum hose onto the MAF pipe nipple.
Old Aug 4, 2005 | 12:21 PM
Kronik's Avatar
heh! I did the vaccuum hosing trick for the stock solenoid too!
Old Aug 4, 2005 | 03:00 PM
hawaiievo's Avatar
sweet thanks guys
Old Aug 5, 2005 | 12:57 PM
nutnbutturbo4's Avatar
with this being said.... Ive had my blitz sbc type s (solenoid boost controler) for over a year now and i have the factory solenoid just bolted up and pluged in... with NO hose... and NO ses.... so why is it necessary to plug it off... whats up.... it boosts just fine... no taper or nothing... but when i turn it off the turbo runs off the actuator 10-12psi
Old Aug 5, 2005 | 01:02 PM
tbizzy85's Avatar
That's odd my blitz set off the code right away, then I realized I should just loop a vacuum line on the solenoid.
Old Aug 5, 2005 | 11:27 PM
DragNRacing's Avatar
A small screw in the end of the hose works great. A little ghetto but mine aren't visible.
