Advice: Seat belts
Old Aug 16, 2005 | 07:00 AM
datdjrobp's Avatar
Advice: Seat belts
I just put a set of racing seats in my Lancer and would rather not have to use a set of harnesses for everyday driving. After looking at the stock seats, I saw that the seat belt receptacle could be unhooked from the seat. Do you guys think it would be safe to bolt those onto the racing seat brackets and continue to use the stock seat belt?
Old Aug 16, 2005 | 07:29 AM
Kyoichi Sudou's Avatar
Just be sure its securely fastened, I'm not responsible for what happens.
Old Aug 16, 2005 | 07:44 AM
RAWMR's Avatar
I would try to check with the seat manufacturer.
RAW
Old Aug 16, 2005 | 09:02 AM
jjm4life's Avatar
id have to agree. call whoever built the seat they will know for better than us, unless you post up what type of seat it is then maybe somone can give you better information
Old Aug 16, 2005 | 10:58 AM
MRinChrist's Avatar
As long as the geometry remains pretty close to OEM, I wouldn't see a problem. You want to make sure the bolt location is secure....Get some CG-locks if you don't want harnesses.
Old Aug 17, 2005 | 08:10 AM
trinydex's Avatar
that is the only way to run it. if you have a rmr brackets they are built this same way, retain oem belts.
Old Aug 17, 2005 | 09:10 AM
wallyevolution's Avatar
I would check with the manufacturer
