ISP GT42r dyno #'s......
Old Aug 25, 2005 | 04:37 PM
  #46
EVOMIZ's Avatar
so how much power did the t76 make?
Old Aug 25, 2005 | 04:49 PM
  #47
jjm4life's Avatar
insane amount of power. id love to see a video of a 1/4 mile run once you get the spray and cams worked out.
Old Aug 25, 2005 | 04:51 PM
  #48
DynoFlash's Avatar
Best of luck at the track - should be fun !
Old Aug 25, 2005 | 05:21 PM
  #49
go_evo_go's Avatar
ummm, no other words then WOW
Old Aug 25, 2005 | 05:35 PM
  #50
Precision Dyno's Avatar
ISP,
Great job on the numbers, BUT I have to add that even with the Tomies you plan to run I seriously doubt you will see anything that will resemble a curve. Even if the vehicle is designed for nitrous.
I have tomie's in My car. Great pair but I just don't know with that graph and your particular setup....
I wish you luck at the track this weekend. I know you will do well.
Old Aug 25, 2005 | 06:02 PM
  #51
Shearer's Avatar
Awesome numbers, 800+ w/o juice is impressive! I have a couple questions, please don't take it as hating because I am curious.
What size exhaust housing are you using? For a 42 that is an extremely weak powerband.
I've never seen a torque peak at ~8300rpm's what is up with that?
And what is with the different gain factors on the two sheets? How does that effect the graph?
Old Aug 25, 2005 | 06:27 PM
  #52
04AWDTURBOEVO's Avatar
Nice power , but how does it drive on the street? I would think it feels like a N/A until 6.5K where the rush snaps your neck back for the next 2500 rpms.
Old Aug 25, 2005 | 06:31 PM
  #53
11secEVO7's Avatar
nitrous should change the curve quite a bit
Old Aug 25, 2005 | 09:10 PM
  #54
A418t81's Avatar
Might have to do with the dyno (hopefully? ). Dynapaks are cool because you can simulate ramp-up load/speed, etc and well as tune at different loads as well. If the ramp up and load isn't quite right compared to what would happen on the street, it can affect spool up, obviously. I've seen it happen at other shops that had fairly new dynapaks that weren't totally dialed in correctly.
Old Aug 26, 2005 | 09:18 AM
  #55
ISPracing's Avatar
Shearer: We are also discussing the torque peaking @ 8300rpm's, we believe me might have the answer.
Old Aug 26, 2005 | 07:25 PM
  #56
Spec'd's Avatar
Awesome-tageous
Old Aug 28, 2005 | 01:28 PM
  #57
34Turbo's Avatar
Thats one of the steepest powerbands I have ever seen. Impressive though!
Old Aug 28, 2005 | 01:37 PM
  #58
scorke's Avatar
Well if your discussing the issue and believe you have the answer do you care to share it?
Scorke
Old Aug 28, 2005 | 02:10 PM
  #59
TheSpeedFactor's Avatar
great job pete and mark!
Old Aug 28, 2005 | 02:18 PM
  #60
Curt@MrLed's Avatar
Former Vendor
hmmm, pm sent..
