spark plug ?
Old Sep 6, 2005 | 04:09 PM
unknown2's Avatar
spark plug ?
What spark plugs should i be running with these mods:
Injen intake w/ upper IC
AMS lower IC
SS-PRO 1 header
APS 3" TBE With test pipe
GSC CAMS 272in 264 ex
21psi daily and 24psi on race gas
Dynoflash
Neisi FMIC
Walbro255
Thanks
Chris
Silver 05 EVO
Old Sep 6, 2005 | 04:14 PM
dsm95hybrid's Avatar
Mods have almost nothing to do with spark plug selection. FYI.
It is boost and load related. Indexing is more important than heat range IMO.
The BPR8es is a well rounded solution. 7es have a better idle in my experience.
0.026 is a great gap. .022 is too small for a Iridium plug DrMR. It is a waste of an expensive plug. You always want the largest gap able to be run. This is why upgrading to DIS-2 DLI or AEM CDI alows you to widen the gap for greater combustion.
Old Sep 6, 2005 | 04:21 PM
dr.mr's Avatar
I have similar mods and have success with NGK BR8EIX gapped to .022.
Old Sep 6, 2005 | 04:24 PM
beavis4g63t's Avatar
a good inexpensive plug is the ngk bpr7es. close the gap to 26-28 and you will be fine.
Old Sep 6, 2005 | 04:25 PM
kmcconn9's Avatar
you have pretty much the same mods as me and I am running the bpr7es..have worked fine for about 2000 miles..you just need to change them more frequently
Old Sep 6, 2005 | 04:26 PM
kmcconn9's Avatar
o and I have them gapped to about .23 if I remember correctly
