how to buid a 10 point rollcage thru the dash board
Originally Posted by SR20DE-T
I dont think they drive there car everyday with that amount of horsepower. plus I got see some dyno sheets to believe you are putting down 700+whp.
Originally Posted by EVIL_EVO_VIII
He made 700WHP, i live in orlando, FL,i live close to his house and the dyno, and i saw the dyno sheet and video myself, he's not making this up.And YES he does drive it to and from work almost everyday @20psi on pump gas.
its build & tune by Central Florida turbo and sponsor by Proccolino’s Pizzeria
http://www.cardomain.com/ride/760982
To everyone this thread is about how to build a roll cage thru the dash board, not about how mush hp my car it doing!!!!!!!!!!!!!!
I will post a thread about it with hp Dyno sheet and video! know back to topic ?
Here's a link that has some pictures of how a cage is routed through the dash. It's not complete, but might help a little.
http://www.cascadeautosport.com/gallery/rally.asp
Originally Posted by 4G63>OOOO
Point is, he's not making 700WHP on his daily driver. Probably with the boost cranked, but there's no way he's making 700 on pump gas unless he swapped in an LS6.
Looks like you need to totally remove the dash and components, put in the cage, then put the dash back together. Doesn't look like it would be a ton of fun, but maybe not as hard as I imagine it to be.
Good luck!
Good luck!
Did i ever say he was making 700whp on pump? NO!! And did u read what i wrote? He daily drives it at 20psi on pump gas which he made 470whp at that boost, whats so hard to believe?
Originally Posted by EVIL_EVO_VIII with foot firmly in mouth
its a daily driver w/ 700+ to the wheels
Someone's confused.
. He drives it at 20psi on pump for daily driver, and high boost at the track. Hope that clears things up
I don't understand why it matters how much hp he has on the street or the strip. Correct me if I'm wrong, but the topic of the thread is supposed to be about roll cages. In his original post he didn't even mention hp #'s. Then someone asked why he wants a cage and he proceeded to explain why. All of a sudden this turns into how much hp on a daily driver, which has nothing to do with roll cages.
. This place is crazy, Eddie was asking on roll cages and this thread turned out to a pissing match. Who the **** cares what hp he is making, he wants opinnions on roll cages. Obviously his car is fast enough if he needs one
. Eddie beautiful car
