(HELP) Dyno Questions
Old Sep 10, 2005 | 06:25 AM
omarv6's Avatar
hi guys ..
ok to the point ... last thursday we dynoed my friends Evo 6 TME and for a reson it wasnt going smothe ...and am not talking about the car am talking about the whole thing .... first the RPM line didnt show ... and we had RPM spike on the dyno monitor .
So the first question here will be where do we connect the cable for the RPM reading ?
we connected it on many places but still we coudnt get it ?
AFR was a bit lean but in the end we increased the fule regulator out put a bit tell it was running 11.5 AFR.
the most important question is .... should we dyno the car on 3rd or 4th gear ...?? what i know is we should dyno on the gear wich is closest to 1:1 ratio and that would be 4th gear .
any way he got about 320 wp wich is kind of ok but we know it can do much more, I say 350 .
the dyno used was a awd dynojet .
I have a 2005 5speed MR and i dynoed it on 4th gear and i got 241WHP when the car was bone stock and no problem i had what so ever.
what i undurstod from him when he called me today is that all tuners are dynoing evos on 3rd and we should of done it on 3rd , when he went back home he was checking the dyno sheets of all big shots like Al fredman and the AMS evo and others and he said the top speed thy made on the dyno runn showed that thy where running 3rd gear where ower runn was way too fast because we where on 4th .
i personly think 4th is what we should dyno the car on .... but my friend could be correct .
what do u guys say .
thax for ur time
Old Sep 10, 2005 | 06:29 AM
hueman's Avatar
i think you're supposed to dyno in the gear closest to 1:1 ratio or whatever it is
Old Sep 10, 2005 | 06:30 AM
omarv6's Avatar
well that what i think ....and that would be the 4th gear .
Old Sep 10, 2005 | 10:02 AM
SR20DE-T's Avatar
I dyno'd my MR on a AWD DynoJet, and rpm pick up should be on the first spark plug wire. But then I have seen some cars have the spike and the rpm go up then down, on the monitor. What we did was play with the pick up placement, sometimes it works sometimes it doesnt.
Old Sep 10, 2005 | 10:14 AM
EVO-6.5 (KSA)'s Avatar
Post
Originally Posted by omarv6
hi guys ..
thax for ur time
dude thanks for the post i had some internet problems that i just fexed naw
any way
i can put some light on the subject
my car has the folwin items so far
Power Fc with comander
aromotive fuel regulator - set at 60psi
HKS evc boost controler set 1.53 Bar peak boost
hard pipes
ARC exhost manifold
three inch down pipe
three inch exhost with HKS drager back box
272HKS cams
HKX cam gears set a 0 degreas
720 Lb ingectors
1)-all the dyno that i have seen are set from aprox 45MPH to no more than 98MPH
that i y i am saying therd gear
2) were can you u get a deacent reading for the RPM ( sparck plug wire , coil wire can some provide a foto with some info for )
help ME PLEEEEEEEEEEEEEEEES
do you think i am in the right range or i should be making more
and thease are my dyno runs
File Type: doc
File Type: doc
Old Sep 10, 2005 | 10:26 AM
omarv6's Avatar
so bro what is the RPM spice cuse by ?
and what gear did u do the dyno run on ?
Old Sep 10, 2005 | 11:00 AM
it was 4th gear
and we wint to 7650RPM in 4th
the spike i have no i dear y did it hapen but i theink it got a wrong reading and that is y it spiked like that
but i would love any help if any one would like to gump in
thanks
Old Sep 10, 2005 | 11:29 AM
ttt
HELP
Old Sep 10, 2005 | 12:18 PM
omarv6's Avatar
where are all the dyno experts ????
Old Sep 10, 2005 | 01:08 PM
u r stell awake ????
Old Sep 10, 2005 | 01:09 PM
no answer y ?
no tme lovers
Old Sep 11, 2005 | 12:34 AM
good morning
some help please ?
Old Sep 11, 2005 | 09:07 AM
omarv6's Avatar
any one want to help 2 bums sitting beside a dyno !?
Old Sep 17, 2005 | 02:38 AM
help
Old Sep 18, 2005 | 03:20 AM
to the top
