Timing Advance guidelines?
Old Sep 13, 2005 | 12:51 PM
lbcevo's Avatar
What is the recommended lower, mid and upper limit (3500, 5500, 7500 RPMs) on timing advance on 91 and 100 octane?
I'm running the following timing, AFR and boost:
91 octane: 19 degrees BTDC at redline, ~11.3 AFR, ~21.5 psi max
100 octane: 24 degrees BTDC at redline, ~11.5 AFR, ~23.5 psi max
Can I go higher on TIMING?
Anyone have general TIMING guidelines for 3500, 5500, 7500 RPMs--91 and 100 oct?
TIA
Old Sep 13, 2005 | 12:58 PM
Nez136's Avatar
im running conervative timming but very sim. to you at redline, at 3500 i think im about 5 degrees and then i go up about 1.5 degrees from there depending on load % at 5500 im at like 10 and 19 at redline (93)
Old Sep 13, 2005 | 01:11 PM
4TUN8's Avatar
What are you tuning with? AEM?
Old Sep 13, 2005 | 05:36 PM
lbcevo's Avatar
Utec
nj1266
Jan 25, 2026 01:43 AM
turboracer
Jun 7, 2011 07:09 PM
Kyle_Y
18
Nov 10, 2007 03:19 AM
Ksyrium11
Jun 11, 2007 06:09 AM
althemean
31
May 2, 2006 12:20 PM
