Kartboy shifter base bushings don't fit.
Old Sep 14, 2005 | 11:29 AM
dan628's Avatar
Lancershop has some metal bushings, I am thinking about order them, they seem like the best ones out there....
Old Sep 14, 2005 | 11:48 AM
mump's Avatar
only in car is what I heard of. now the underhood don't fit the MR because the MR bushings are a different size.
Old Sep 14, 2005 | 12:05 PM
Boston'sEvO-->8's Avatar
well i guess thats good...lol btw is it common when putting an act clutch in even after adjustment that reverse is hard to get into unless u put it into another gear then reverse?
Old Sep 16, 2005 | 11:40 AM
I installed the ones in the car and they didnt fit like everyone is saying so I just tightened them enough so the shift boot wont move does anyone see this as a problem in the long run or in the present time comming? BTW what is the point of the ones inside is it supposed to do anything with the shifting or just supposed to hold the booth in place. I still have not installed the ones in the engine. I will do those monday.
Old Sep 16, 2005 | 01:48 PM
snoop's Avatar
Originally Posted by twEeker
I was trying to install the kartboy shifter base bushing today, and they didn't fit into the plastic base. The smaller part of the bushing is supposed to fit in the hole right? It wouldn't fit no matter how hard I tried to make it. Maybe the place I ordered from sent the wrong ones? Anyone else have fitment issues? help please.
Call Tom. He can help you out
http://www.kartboy.com/index.html
Old Oct 24, 2005 | 06:59 PM
AznaikoN's Avatar
I had this exact same problem too. I thought I was putting them in upside down or something. Theyre still sitting in the bag in the garage
Old Oct 24, 2005 | 07:08 PM
GoneIn420's Avatar
I put the bolt through, hoping it would force it in, but it didnt. I tightened it almost as tight as I could, then took it back out to check. I could see the crease lines around the bushing. I got a razor blade, and cut a little off the edge, hoping is would let the bushing slip into place. Still no luck. so I put the stockers back, and put the center console back together. It crossed my mind to just tighten and leave it, because it felt very sturdy when I did, but I'd like to see how many people have had this issue, and what they did.
Same problem, didn't fit, but to fix it I instead bought Energy Suspension Poly Bushings and they fit perfect, same item just not green. But on a positive side, the engine bay shift bushings fit perfect. Late.
