injector question
Old Sep 15, 2005 | 07:00 PM
moto17's Avatar
injector question
getting a 2.3L stroker kit. can't wait! I was wondering if the stock injectors would be able to handle the extra 300cc of displacement. If not, what size injectors would one recommend and would I need a new fuel pressure regulator for the bigger injectors or is the stock one good? Any input would be greatly appreciated. thanks.
btw I plan on getting a custom tune by dynoflash as well.
current mods:
3" TBE
Cat delete
Megan turbo outlet
Megan Headers
MBC
Walbro 255L FP
K&N drop in
Dynoflash mail in reflash
(stock turbo and cams)
Old Sep 15, 2005 | 07:06 PM
westchester evo's Avatar
No, I had to upgrade to a 660 just to do cams and all the other bolt ons. You want to keep
the duty cycle in the middle, not at 99 percent
Old Sep 15, 2005 | 07:07 PM
And also.....I would look into Turbo-trix for the custom flash
Old Sep 15, 2005 | 07:14 PM
virtex's Avatar
Whats your list of mods bro.... do you have the fuel pump too?
Old Sep 17, 2005 | 09:33 AM
moto17's Avatar
bump
Old Sep 17, 2005 | 09:48 AM
propellerhead's Avatar
If you're sticking with the stock turbo I'd go with 720s. You might be able to get away with 660/680s but you'll be pushing the limits in terms of duty cycle, especially if you visi the track and turn up the boost. If you think you'll be upgrading to a larger turbo I'd go with 850s. On my stroker set up with a GT35 and 850s I'm seeing injector duty cycles in the neighborhood of 60-70% at 43psi. I'd need to pull the logs since the last round of tuning to confirm. Ideally you don't want to be running any higher than 85% IDC although many tuners will push injectors into the 90-95% and haven't seen problems with injector lock up.
Old Sep 18, 2005 | 09:55 PM
moto17's Avatar
thanks man! much appreciated. Just out of curiosity, what additional mods do you have and what kind of numbers and/or track times are you getting?
