stock Psi on 05 ?
Old Sep 15, 2005 | 08:16 PM
josep1001's Avatar
stock Psi on 05 ?
I just bought a Greddy boost controller and I would like to know What is the stock PSI on EVo's
Old Sep 15, 2005 | 08:17 PM
xiaoni420's Avatar
on the 05's...anywhere from 20-21 tapering to 18
Old Sep 15, 2005 | 08:20 PM
josep1001's Avatar
Thanks, and whats tapering?
Old Sep 15, 2005 | 08:21 PM
VIIImylunch's Avatar
when I installed the boost guage it was more like 19 with a tapper to 16. your boost will hit 19psi and then tapper to 16 and hold there.
Old Sep 15, 2005 | 08:22 PM
josep1001's Avatar
So is the top boost 19 or 20-21 stock?
Old Sep 15, 2005 | 08:23 PM
Fa$[- a$ $hi[-'s Avatar
when the boost maxes out at a certain rpm, then the boost falls slightly to a sustained boost pressure. my '03 maxed at 19.5, then tapered to 16ish, before my reflash. now it stays at 22psi.
Old Sep 15, 2005 | 08:25 PM
20 was the most i ever saw stock. Most of the time I would only do 19.
Old Sep 15, 2005 | 08:27 PM
josep1001's Avatar
I thank you all for helping me.
Old Sep 15, 2005 | 08:52 PM
Smoothgangsta's Avatar
I believe by the book the 2005's hit around 19.1 PSI and then drop off to around 16-16.5 at redline.
Old Sep 15, 2005 | 08:54 PM
nj1266's Avatar
At what rpm does the boost hit 19 psi?
Old Sep 15, 2005 | 08:57 PM
romogst's Avatar
19 PSI on most stock evos
Old Sep 15, 2005 | 09:36 PM
werra's Avatar
its like 20.13 stock, tapering to 17 i believe
Old Sep 15, 2005 | 09:37 PM
ancker's Avatar
My 05 boosts to 20.5 and tapers to 17 and has consistently since I bought it in March.
/ancker
Old Sep 15, 2005 | 10:49 PM
All 05's that I have owned (MR and GSR) boosted to just a hair over 19PSI and tapered down to around the 16'ish range.
The factory gauge pack is not completely accurate as say a DEFI D-Series gauge.
Old Sep 16, 2005 | 04:29 AM
get faster's Avatar
Stock boost comes in at 19psi then drops to 17psi. Before you go cranking up the boost make sure you're using high enough octane fuel or else you move slower, even with a higher boost reading. It's been said in the forum that 20-21 psi should be the highest you should boost on pump gas. Do a search of past treads on this subject.
