exhaust issues to look for?
Old Sep 16, 2005 | 08:28 PM
supravital's Avatar
i ordered the turbo back exhaust from megan racing and i was wondering if there will be any issues that i will have or eventually have with my car?..i.e such as stalling issues or even idle issues...this is my first turbo car so i am a noob to modding a car with these specs...its not a honda like im used to having so anything help..i just dont want to put an exhaust for power if im gunna be irritated with the problems....thanx
Old Sep 16, 2005 | 09:17 PM
AWDrift07's Avatar
Megan Racing makes a decent exhuast. Just make sure you use new gaskets and torque everything to spec. If your TBE is catless, you will have to swap back to your stock exhaust when emissions test time comes. TBE exhausts are usually louder than stock. And if you are running catless, you will definitely be louder than stock. If you are catless, you will notice a very small amount of black smoke, this is normal because of the conservative, rich afr the Evo comes with from the factory. Your performance exhaust shouldn't give you any more problems than the stock exhaust as far as maintenance.
