installing aps bov need help.
Old Sep 24, 2005 | 10:04 AM
EvoDan2004's Avatar
i just got it in and i want to put it in. the car is stock. can i just put it in and drive or is there any addjustments i need to do? also pics on intall would be great seening is how i dont no what gos where. thanks guys
Old Sep 24, 2005 | 10:09 AM
bigjhoney's Avatar
Adjustment should be fine out of the box. Install it so the vacumn nipple faces the ground, nearest to the fan.
Old Sep 24, 2005 | 12:45 PM
ctx2000's Avatar
just plug n play, no adjusment.
Old Sep 24, 2005 | 03:29 PM
EvoDan2004's Avatar
up date, installed and wow im loven it. ps evos should all have it. put it in drive off and enjoy. thanks guys
Old Sep 24, 2005 | 03:35 PM
MrMejia's Avatar
Is that a recirculating or vent to atmosphere BOV?
Old Sep 24, 2005 | 03:37 PM
EvoDan2004's Avatar
bouth. under low boost it is resec when under high boost it is like 50 50. the valve kicks but
Old Sep 24, 2005 | 03:40 PM
MrMejia's Avatar
then you will need to flash for that because its losing power and sounding nice all at the same time
Old Sep 24, 2005 | 03:41 PM
mpevo8's Avatar
by far the best bov ever made
Old Sep 24, 2005 | 03:45 PM
MrMejia's Avatar
uhhh.....no. but it is nice. For his stock evo I would recommend the MR JDM or WORKS diverter valve.
Old Sep 24, 2005 | 03:46 PM
avaien's Avatar
Not true. The valve recircs all the air except for when under high boost. You don't have any problem with staling out or such. I just put mine on yeseterday and the car pulls stronger due to my stock bov leaking!
tcarretti's Avatar
how do you figure that it's losing power? It's a recirculating valve that only opens the secondary port under higher boost. You don't need a flash for this BOV...........
Tony
Old Sep 24, 2005 | 03:51 PM
MrMejia's Avatar
How can you tell it pulls harder? you cant measure 5hp or less with your butt.....
no you dont "need" one but it helps.
Old Sep 24, 2005 | 05:45 PM
EvoDan2004's Avatar
it deff pulls harder in the upper rpm. also my car is stock but i have alot on the way. should arive this week. im glad i got this valve. thanks all for your help. any1 have any ?s about this valve pm me. thanks.
Old Sep 24, 2005 | 09:52 PM
joeymia's Avatar
You ask if you APS vents to atmosphere but then say you will need a reflash with it? How can you be a credible source if you had no idea what the APS did? I have an APS bov and I do know for a fact that I never lost any power. Infact I was actually holding boost better up top which is what evodan2004 was feeling.
Old Sep 24, 2005 | 10:01 PM
EvoDan2004's Avatar
i love it. i cant wait to get my other stuff in so i can get her tuned and on the road for some evo pimping. lol ? for you tho with an intake will i here it beter on low boost and high boost louder then it is on stock air box. i really dont care bout the nose im more for the performance side if it but hea its my 1st turbo car let me live for a week. lol
