Forge Bov Help!!!
Old Oct 3, 2005 | 10:27 PM
Silver05Bullet's Avatar
Forge Bov Help!!!
Got the forge BOV on dont know which spring to use, i think its pretty much good now but i get a little bog shifting from 1st to second possibly because of it, anyone with a Forge BOV which spring are u using and how many Washers?
Old Oct 4, 2005 | 06:32 AM
bump
Old Oct 4, 2005 | 10:29 AM
Come on someones got to have a forge BOV
Old Oct 4, 2005 | 10:31 AM
nutrulz's Avatar
not sure what spring to run, but I know if you run it backwards it works better. contack Mike@Forge here on EvoM
PoorBoys's Avatar
I am still using the spring that came in it. Never had any problems with it, and I never had to change it out.
Old Oct 4, 2005 | 10:37 AM
PoorBoys do you know what color is the spring inside, or do you know which ones your not using?
And how could it work better backwards can you explain that?
Old Oct 4, 2005 | 09:41 PM
PoorBoys's Avatar
I am using the blue spring, but I don't know about the backwards thing...
Old Oct 5, 2005 | 08:15 AM
For anyone using the Forge BOV and wanting to know this too i found we should be using the blue spring its good between 19 and 25 psi.
Old Oct 5, 2005 | 08:16 AM
tke_413's Avatar
I'm using whatever spring was in it when I got it
Old Oct 5, 2005 | 08:22 AM
Anarchy99's Avatar
That would be the Blue, on the side of the box there should be a colord dot and that will tell you what spring is in it.
