Mod List Power Estimate?
Old Oct 10, 2005 | 11:06 AM
J8dailo's Avatar
i just made a list of the mod route im going... can someone fill me in if i need something else? im wanting to keep stock ECU as long as possible and Stock turbo
Apexi Power Intake
Cyberspeed voltage/ground system
LPI Upper and Lower IC pipes
Fujitsubo Exhaust
A-Spec Ti Test Pipe
Downpipe
Greddy Profec B II
Gauges
Aps BOV
264,272 Cams
Walbro Fuel pump
Fuel Injector
Alky Injection Kit
Mini Battery kit
Custom Tune/Flash
how much HP and 1/4 Mile and my looking at? im guessing 400hp+ and high to mid 11sec..
Old Oct 10, 2005 | 11:07 AM
J8dailo's Avatar
is there something else i should add for safety? and all this running on pump gas 93 octane
Old Oct 10, 2005 | 11:10 AM
Warrtalon's Avatar
There's nothing you should add, but there's lots you should remove/change unless you don't mind throwing away money randomly. You will be more like 350whp and low 12s with these mods. Nowhere near 400 and mid 11s...only high 11s if you're an incredible driver and everything is installed and tuned perfectly.
Old Oct 10, 2005 | 11:11 AM
J8dailo's Avatar
yes, from what i seem... people running stock turbo with supporting mod with alky injection got pass 400hp... what else am i missing?
Old Oct 10, 2005 | 11:18 AM
Warrtalon's Avatar
Originally Posted by J8dailo
yes, from what i seem<---???... people running stock turbo with supporting mod with alky injection got pass<---?? 400hp... what else am i missing?
Not what I've seen, especially on 03/04s with the 9.8 hotside. This is the problem with people posting inflated dyno numbers...it makes others have unrealistic expectations.
Other items to get you above 350whp would be a standalone or advanced piggyback that could provide more intense tuning, an FMIC, a 10.5 hotside, a tubular manifold, and a ported o2 housing.
Old Oct 10, 2005 | 12:30 PM
Jared622's Avatar
^^ listen to warrtalon man he knows his ****. Don't feel bad though with my mods I only threw down 248 HP on buschurs MD. I had a slipping clutch though. So I might be just a tad higher
Old Oct 10, 2005 | 02:12 PM
J8dailo's Avatar
damn....not sure what else to add to reach there...there are people that done it like curt brown... i saw a member got 468whp..or around there with stock turbo....
maybe add an magus intake manifold, tubular manifold, O2 housing, 10.5 hotside...
this is harder to do than i thought...
