safety harness??
Old Oct 16, 2005 | 12:46 PM
Big Shooter's Avatar
safety harness??
im just wondering whats the best type and or brand for easy install on a daily driver. i plan on using the normal belt for everyday driving and the harness when im about to do something stupid. from pics it looks like you have to run them to the backseat. how does that work do they just clip in to the female part? cause that would be slick.
Old Oct 16, 2005 | 01:10 PM
sk8bored's Avatar
I have the rally 4, the quick disconnect works really well.
http://www.roadraceengineering.com/evosafety.htm
Old Oct 16, 2005 | 01:18 PM
jdnourse's Avatar
I like these too. Easy install
here you go
https://www.evolutionm.net/forums/sh...ad.php?t=81650
Old Oct 16, 2005 | 03:41 PM
liveiiroll's Avatar
here you go
awesome thread i want to do just that!
Old Oct 17, 2005 | 02:59 PM
is it 160 for one? or a set?
Old Oct 17, 2005 | 09:20 PM
undrcroft's Avatar
just get a cheap generic 4-point harness off ebay. You can get one or a set. As long as it looks pretty heavy duty, it's fine. I got one with the brand Volo on it for like $30 . Thick *** mointing bolts on 'em too. I mounted the bottom bolts to the original bolt holes on the seat and on the frame, then the top two bolts above the back seat. Used the bolt that was holding in the rear upper driver side seat belt and took out the upper middle belt tensioner and put a bolt in there...perfect. heres pics.
Just make sure you tighten from all four ends before you drive, always
