how much $ will it take?
Old Oct 16, 2005 | 02:03 PM
shingo's Avatar
To get into the mid to high 11's on the street?
Old Oct 16, 2005 | 02:04 PM
AznFlip's Avatar
Buy AMS stroker kit and their turbo kit. 5-7g? Btw, did you meant 11's on the strip?
Old Oct 16, 2005 | 02:08 PM
evo_il8's Avatar
i would only, do that if i was the worst driver ever, that combo would take u into the 10's not 11's. all u need to run 11's is cams, tune, tbe, alky injection, intake maybe, boost controller
Old Oct 16, 2005 | 02:10 PM
AznFlip's Avatar
and probably MR bov or other good ones out there?
Old Oct 16, 2005 | 02:14 PM
Kwman's Avatar
You can buy my car
</shameless plug>
Old Oct 16, 2005 | 02:33 PM
Z1 Performance's Avatar
that will net you 11's on the track....if you are a good driver.
Forget about the timeslip....gotta decide how much power you are after
After that, you can do it cheap with inexpensive products and you can do it expensive with higher end, more exotic products. In some cases, the cheap stuff works ok, in other instances, it's not even worth it's cheap entry fee. Conversely, some of the expensive stuff is not worth it, some of it is. All depends on what your budget will allow and what you want your car to be.
Old Oct 16, 2005 | 02:47 PM
Hotshot940's Avatar
That is an excellent point, could you site some examples of parts / manufacturers that cheaper products would be alright for, and what expensive parts wouldn't be worth it. Many people think spending the most means your getting the best, but i think that's not entirely true, altough sometimes spending more and a quality named product gives a little bit of a sense of security since your buying from a top brand.
Old Oct 16, 2005 | 03:03 PM
liveiiroll's Avatar
i dont know too much about this but vishnu has a lot of products and they give you est 1/4 mile times, etc.
