somethign is wrong with my car
I need help.. currently my turbo is working well below 4k.. it'll hit max boost then all of a sudden the evc tells me i overboosted to around 24.7 i usually hit 21.7 on the evc on the current set up... then after 4k.. no power at all.. its like my engine makes 10 hp and 3 tq after 4k in boost.. or maybe theres no boost.. but when i drive normaly up to 4k not under boost its okay
sounds like your overboosting and the car is going into limp mode, fuel cut, or whatever else it is. you say the evc told you that you were boosting to 24.7.. so what does your boost gauge say? if it also says 24.7 than i think you need to play with the evc to lower that boost.
