Something very bad just happened...HELP
Old Nov 2, 2005 | 03:29 PM
deffro's Avatar
I drive a 2005 Evo with right at 3500mi on it. Iwas just leaving school, going about 5 mph and got on the car a little leaving the parking lot. The car bogged down as I heard a loud WHOOSH sound, almost sounded like somebodys blow off valve or something. The car now idles fine but will only go about 20mph and 1400rpm at which point it just starts skipping and jerking, staying at that speed. I was close to my house so i just limped home. I installed a Forge MBC last week, but other than that I am stock. Any ideas?
Old Nov 2, 2005 | 03:32 PM
Stealth-Ghost's Avatar
Cat in your air intake!
That's weird man, take it to the dealer i'd say, but if you can only go 20 that might not be an option.
Old Nov 2, 2005 | 03:34 PM
05evo's Avatar
did you check all the piping...specifically the piping to your intake\bov\intake mani?
Old Nov 2, 2005 | 03:35 PM
zze86's Avatar
Have you popped the hood and checked anything?
Evolving-04's Avatar
boost leak. check around the bov since you just messed with it.
Old Nov 2, 2005 | 03:36 PM
superflyevo's Avatar
blew off a boost tube some were
thats what mine did and it was doing the same thing
look at all the ic piping look were the bov hooks to the ic piping
deffro's Avatar
I haven't checked **** yet, just waiting for the car to cool off.
BoostWhore's Avatar
yeah hose came loose
zze86's Avatar
well take a look first, things might be quite obvious once you pop the hood.
Old Nov 2, 2005 | 03:37 PM
deffro's Avatar
God I hope thats what it is. That is what i figured, simply because of the loud sound.
EvOJoHnY0312's Avatar
do this put your stock bov on and take it for a spin and if the problem still persist just take it to the dealer and telll them your problen but whatever you do dont tell them about the aftermarket bov you had on
4g63girl's Avatar
sounds like one of the charge pipes popped off....check all ic pipe connections.
emery
V8EaterEvo's Avatar
It sounds like you hit boost cut and it stuck.....Check your lines, one might have came off.....Was your car cold.......The Evo's have a saftey feature that if they are cold, they will boost cut very early.......Don't waste your time with the dealer, they will tell you BS and charge you because you moded your car and something happened.....Keep us informed.
Old Nov 2, 2005 | 03:39 PM
deffro's Avatar
I have the stock BOV on it, just added a boost controller
Old Nov 2, 2005 | 03:42 PM
deffro's Avatar
Intercooler pipe connection........WHEW! Thanks alot guys.
