Cam Gears
Old Nov 4, 2005 | 10:17 AM
Aux.'s Avatar
Cam Gears
Ok i am either the biggest Douche or i am retarded (Deet Dee Dee). Can someone please give me a run down on what the hell Cam Gears are and what they do ? Also if i was to upgrade them what good would it do for me ? I searched and didn't find anything and i even googled it before i posted this so could someone please help ?1 I mean i know what cam shafts do , but not cam gears!!
Old Nov 4, 2005 | 10:20 AM
en1gma19's Avatar
Cam gears adjust the timing of the cams. You dial in more or less overlap to help with spool characteristics, improve idle and shift the powerband up or down in the RPM range.
By themselves, they may offer little if any gain, but when upgrading the cams, gears will give an added range of adjustment, and the ability to tweak the car to your personal specifications.
Old Nov 4, 2005 | 10:31 AM
Big Shooter's Avatar
cam gears are like butta, and they look perdy
nirvevo's Avatar
What the first reply said plus this:
It's important to note that adjustable cam gears have no direct effect on the duration and lift of the valves, that's the job of the camshaft lobes (profile) as dictated by the cam manufacturer.
*TIP - Always make sure your cam gears are tightened correctly to combat cam gear slippage. Slippage refers to the bolts that hold your cam gear to the settings you desire loosening up and allowing the cam timing to advance or retard fully often with catastrophic results. DO NOT LET THIS HAPPEN TO YOU. And not to state the obvious, but... make sure your car is in tip-top working order before you adjust your cam gears.
Generally, advancing a cam gear opens a valve sooner, and closes it sooner... retarding the cam gear, opens the valve later, and closes it later... since all you've done is "move" the fixed event.
Advancing Intake and Exhaust : This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier but will not increase it.
Retarding Intake and Exhaust : This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only : This will help the cars top end, and it reduces overlap.
Retard Exhaust only : This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once. Very common DSM modification.
Advance Intake only : This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once, although isnt a very common mod for DSMS.
Old Nov 4, 2005 | 10:36 AM
Pd1's Avatar
Pd1
This is worth a read if you haven't seen it already...
http://www.automotosports.com/magazi.../camshafts.pdf
Old Nov 4, 2005 | 10:55 AM
Aux.'s Avatar
You are so the "POO" dude , thank you . That is exactly what i needed and on top of that if someone else needs a tutorial on,if they need cam gears yet , this will be it !
Old Nov 4, 2005 | 12:09 PM
nirvevo's Avatar
It's a clip out of a larger article, but it does sum things up. Glad if it helps. I'll bet there is a bunch more to learn, but it's a start.
