Oil Change Question on my 06 MR + Picture
Hey guys! Just trying to do the first oil change on my MR. Okay, so I get the car jacked up and noticed the oil drain plug has this nylon (safety cord?) attached to it so I can't get a socket over the drain plug. Do people normally cut this or what's the standard procedure? Please help! Try to get this done tonight. Thanks!
Stressful day for me. I was out driving the car here in WI when this hail storm came out of nowhere! I managed to get under a building overhang in just a couple minutes so there was no damage. What a scare to hear that sound on my new two week old Evo! The hail was between pee and small marble size. As I heard the sound I was thinking, "There goes my aluminum hood and roof".
Here's a picture I took last week.
Originally Posted by imapunkclaimer
its not a safety cord. its the sensor for your oil temp sensor on ur gauges. use a 19 (i think) mm wrench on it open ended and itll come off
Can anyone confirm that I need a 19mm wrench on the unique 06 MR drain plug?
im like 90% sure its 19mm. i remember it being an odd size. if you dont have one you can try out an open end adjustable for now, but dont strip it. i dont think u can get a socket over the plug.
Originally Posted by itrsport.com
But how can I use my torque wrench and socket to snug the drain plug to 29ft-lbs?
btw - nice ride
whoa....i know this dosent help but weve met on hwy 100....im the black evo that you were speaking to outside of renner on friday night......
anyways...back on topic
Originally Posted by BuLocal
I was in Brookfield looking at houses when that hail started coming down, does the hail get much bigger than that??? I was in a rental car but it still sucked.
Don't move to crookfield, er uh brookfield. Try Franklin, better people, better houses and cheaper taxes.
Originally Posted by Fireball
Looks good Josh.
If you still need help w/ the oil change, let me know... should have remembered to tell you about that oil temp sender.
