Anyone running Buschur TB w/ a different dp?
yes i am, if you think about it its all the same 3" stainless steel tube. As long as you tell them so the connetion to the cat or test pipe are the same. they do slip on but weld the regular bolt on way if you tell them to
I already have a full buschur tb with the flange at the test pipe. My dp is leaking at my tubular 02 housing so im looking at using a dp that uses the factory gasket
