need help asap i.e brakes
Old Nov 8, 2005 | 08:39 PM
supravital's Avatar
i understand i need high temp anti seize for the back of my brake pads..the only autoparts store i have around here is autozone and kragens and they only carry permatex high temp anti seize...i cant find copper anti seize or 1800 degree temp at that..the only thing i can find is the high temp anti seize that stands up to 1600 degrees....the question is....will this work??it is only 1600 and non copper..please help..thanx
Old Nov 9, 2005 | 03:06 AM
trinydex's Avatar
uhm... you need brake pad grease... not antisieze... they should sell it in the brakes section. mine came in these little ketchup packet like things. it's not really a grease either... just something you put on and after a while it kinda gets really thick, almost solid so you don't get vibration noises and squeeks.
Old Nov 9, 2005 | 03:09 AM
ChopShop's Avatar
+1
Old Nov 9, 2005 | 05:53 AM
HiRevnVIII's Avatar
you can mix anti seize (about 10%) with sythetic brake grease and that will help to achieve whatever you're trying to do. putting grease on the back of the pads is a good thing to do unless its a one piece pad in which it will absorb into the pad and cause issues down the road. But yes, put sythetic grease on the shims and it will "help" prevent squeaks. But if youre getting your brake pads up to 1600 degress, WOW!
Old Nov 9, 2005 | 06:18 AM
TxEvo8's Avatar
I used the same stuff that you're using (1600 deg.), no brake squeek whatsoever.
Old Nov 9, 2005 | 09:05 AM
evoCS's Avatar
I had a local parts store(non-chain i.e. Autozone, Kragen, etc...) special order that Permatex high temp copper anti-sieze. They got it pretty quick. I tried the other anti-squeal stuff and it didn't work very well at all on the Endless pads I was installing. Though I wasn't re-using the stock shims at that time. I reinstalled the pads with the shims and the copper goo and all's quiet
Old Nov 9, 2005 | 04:35 PM
Barnettevo's Avatar
I am having the same problem! Can't find the Permatex Copper Antisieze at Pep Boys or Autozone. I will probably order it online and have to pay shipping. I used the basic brake grease in the little plastic packets from Autozone, and my brakes are squeeking like crazy.
Old Nov 9, 2005 | 05:36 PM
91GSX's Avatar
i used the standard brake grease from the packets and 1k miles into the brakes without a chirp. the copper is preferred... but in my case (probably lucky for now) it wasn't a must
Old Nov 9, 2005 | 07:18 PM
Aikido's Avatar
is the brake grease something necessary when changing brakes or is it just an option?
Old Nov 10, 2005 | 09:16 AM
evoCS's Avatar
Yes, I believe it is needed. The stock pads require it too. I've seen the little packets of stuff the dealer uses, and it looks very much like the copper anti-sieze.
