3" test pipe gaskets??? where to buy for cheap?
I need 3 3" evo testpipe gaskets. Cheapest I can find them is $11 a piece from lancershop. Anyone know where I can get these cheaper? Thanks
Originally Posted by KevOVIII
The descriptions are "GReddy 80MM oval exhaust gasket." Are they really oval or are they circles?
The flanges on the Buschur downpipe to cat leak.
Originally Posted by 4TUN8
Everything you get from buschur either leaks or doesn't fit right, but if you fix those minor little things, he makes more power then anyone =p
Originally Posted by timzcat
That is the part number and by oval I think they mean 2 bolt flange so yes it is kind of oval. I am running the exact gasket from an RMR DP to a Buschur Cat.
Thanks for the info.
First of all they are not easy to find. Some of them are advertized as 3" but they are really not.
I order once a truly 3" gasket from Greddy. Ironicly it was $11 also. You wouldn't find much cheaper than that neither much better either. Go with Greddy.
I bought a sheet of exhaust gasket material at Autozone and made my own. Took about 10 minutes, and my Buschure TBE no longer leaks. I just used a 3 in. hole saw to cut it out. I am so happy with this exhaust now. It is quiet and makes good power. Good Luck
