check engine light...
Old Nov 26, 2005 | 10:03 AM
yia_lanevo8's Avatar
okay, i have just installed a DC dp w/ cat delete and an HKS carbon ti exhaust. my check engine light came on. Checked it and it was pointing to the o2 sensor so i checked all the bolts and gasket and nothings wrongand the o2 is screwed in too...can anyone help me out....thanks
Old Nov 26, 2005 | 10:07 AM
4TUN8's Avatar
This has been covered a thousand times. Next time I suggest you search for your problems. That being said.
Not having a cat is causing your CEL to come on, you can fix this for about 10 dollars in parts total.
Go to autozone, find 18mm spark plug non-foulers, drill one out with I think a 1/2 inch drill bit, screw them both together, put your 02 senor in the assembly and back into your exhaust, no more CEL.
Do a search on CEL fix for test pipes, actually I might find it for you.
Old Nov 26, 2005 | 10:08 AM
4TUN8's Avatar
https://www.evolutionm.net/forums/sh...&highlight=CEL
Old Nov 26, 2005 | 10:31 AM
thanks
