greddy type s bov
Old Nov 26, 2005 | 05:26 PM
kyle21's Avatar
greddy type s bov
hey, ok im installing it right now and i got it vented into the air intake and the flange connected and the one tip hose too.. i did the single spring mod, so i dont have to connect anything to the lower nipple. but what do icap it off with. i have it pretty loose right now and when i barely rev it up it sounds like a whining girl.. plz need help thanks
Old Nov 26, 2005 | 05:39 PM
EVOJACK55's Avatar
bump to help this guy, i don't have the answer, maybe tighten something
Old Nov 26, 2005 | 05:41 PM
Hotshot940's Avatar
the one nipple shouldn't need capped
Old Nov 26, 2005 | 08:10 PM
kyle21's Avatar
i put both springs back in, i capped the intake hose and i connected the nipples with a three way cross over that came with it.. even with the 2 springs in, i hit boost and it starts yelling and sounds like a turkey then it chirps a little. what am i doing wrong? thanks
Old Nov 26, 2005 | 08:12 PM
RalliArtEvoVIII's Avatar
no nipple needs to be capped, leave it open, as for ur whistling, its probably too loose, take the screw all the way out then start over and turn it about 2.5times and lock it and keep testing and tightening from there, PS: i've used over 7 bov's and this is the best 1 PERIOD besides tshe MR DV
Old Nov 26, 2005 | 08:23 PM
egui42's Avatar
You capped off the intake hose? Are you venting to atmosphere? You need to have 100% recirculating BOV if your not tuned for venting to atmosphere. I have this BOV, and it holds boost like crazy when you do the single spring mod and connnect the 3rd nipple. (done by DSS and by RRE)
Old Nov 26, 2005 | 08:25 PM
kyle21's Avatar
ok i have the large spring back in now, so do i connect it to the intake port and put the flange into the ic pipe or do i leave the intake pipe open? do i just leave the nipples alone or do i put that one hose on to the top one? thanks 4 ur guys help
Old Nov 26, 2005 | 08:26 PM
kyle21's Avatar
do i need any thing to recuirculate the type s to my stock air box?
Old Nov 26, 2005 | 10:40 PM
Jakeg97's Avatar
it should look something like this when installed = https://www.evolutionm.net/forums/sh...0&postcount=12
https://www.evolutionm.net/forums/sh...d.php?t=113527
Old Nov 26, 2005 | 11:17 PM
no, greddy type S has no recirc kit needed, u just plumb the opening where u took the stock BOV out of. Same setup as if it was stock
Old Nov 27, 2005 | 09:09 AM
kyle21's Avatar
ok i have both springs in now, it flutters no matter what but i only have the upper nipple connected to the vacuum port, what do i do with the lower nipple and what adjustment to get the flutter to stop. thanks
Old Nov 27, 2005 | 11:41 AM
Jakeg97's Avatar
its gonna flutter at low boost shifts
Old Nov 27, 2005 | 03:06 PM
kyle21's Avatar
I still cant figure out what is wrong with the bov, i tryed both single spring and duel spring and i put it in with the flange in the turbo pipe and the other end to the intake pipe but i hook up the hose to the nipple closest to the purple cylinder and it makes the same noise no matter what, chu chu chu chu, tight or loose it all makes the same noise. i saw that when i opend the bov the rubber piece was sortof bent out of shape, could it be that, i also have my bov where the adjustment screw is facing up, plz need hlp what am i doing wrong?!
Old Nov 28, 2005 | 08:47 PM
Drill_Sergeant's Avatar
Veteran: Army
facing up? the adjustment screw should be point towards the front of the car. sounds like you have it in backwards
Old Nov 29, 2005 | 08:37 AM
kyle21's Avatar
ok there is two openings and you put the flange on the bottom farthest away from the purple top right? then you take the flange and connect it to the intake pipe which is on the right side and put the other port into the bottem hose next to the turbo right? i did that and i connected the hose and i adjusted to any setting and it would just keep leaking or somthing, it sounded like a turkey then it would blow off. then i switched it so the flange is on the bottem and now it dont leak and it flutters and even though i switch out the springs tehy all make the same noise, like a flutter at any setting. what am i doing wrong? thanks
