Evo IX STOCK dyno'd at Topspeed with VID
While we're on topic about claimed factory horsepower ratings, did anyone catch the article one of the big car mags, not sure if it was MT or Automobile, but there are new guidelines for 2006 for claimed HP. Guess what?
Toyota's car's were overrated.
Acura's car's were overrated.
GM's cars were UNDERRATED of course!
you are supposed to break in the other way. rev like crazy for the first 20 miles. Then you take it easy till 1k. that first abuse will make the piston rings expand to the wall and seated perfectly tight. if you didn't do this, you missed your chance to seal it perfect. after 100 miles, rings will set in loose manner and they won't be any tighter.
Originally Posted by Lgkaos
My IX was also hella properly broken-in...never above 3500RPM,etc.
That's hella NOT properly broken-in. Who made you think you shouldn't go above 3500rpm. That's the opposite of what you're supposed to do. You HAVE to go above 3500rpm and get into the boost so that the rings seal. If you didn't go over 3500rpm, then you never boosted. The Mitsu manual says not to go above 5000rpm, not 3500rpm.
i guess i understand why he thought that was a good idea. hopefully everything will end up alright on his car anyway.
also dont forget all u evo IX owners, when u feel the need to change that gorgeous turbo, please PM me. thanks!
Originally Posted by Rastmp
My stock Evo 8 dynoed at 277WHP with a hard brake in.....first 100 miles ...
Every car is different, and there are many variables...assembly, break-in, quality control...etc.
Where in CT did you dyno your car and what dyno did they use? Thanks!
Slightly off topic... has anyone put an Evo IX head on a flowbench and done an apples to apples comparison of the flow characteristics with the Evo 8 cylinder head? I suspect the head design and casting quality of the Evo IX head are provide for better flow.
- SRT-4s - When these came out, they were listed at 230hp or so? Well, when people started dyno'ing them, they were showing that much power AT THE WHEELS. Why did Dodge advertise the wheel HP instead of an estimated crank HP? I have no idea, and I don't know if it is public knowledge, but I know they responded to the questions by "raising" the published HP the next year even though power output wasn't changed.
P.S. Congrats to IX owners, very very impressive.
