Mitsubishi Dealer Recommendations
I'm looking for a mitsubishi dealer that you guys go to in the LA area. I have an '03 evo and just that I have a coolant hose leak. It's the hose coming from the oil cooler and it leaks around the metal fitting on the hose. Glendale mitsu quoted $88 for the hose. I thought that was a little high...is this assumption correct? where do you recommend for economical mitsu OEM parts?
Is it the the top hose from ur radiator because if it is then Mitsu is supposed to cover it under warranty because there was a recall on that and Mitsu fixed mine...........
