Parking brake light stays on
Old Dec 19, 2005 | 07:45 AM
infin|ty's Avatar
About a week ago my parking brake light would stick on, and if I wiggled the handle it would eventually shut off. Now it stays on all the time, or turns off on acceleration and back on during braking. Any ideas? It's very annoying cause it's so bright especialy driving at night.
Old Dec 19, 2005 | 07:59 AM
Dave2's Avatar
check brake fluid
Old Dec 19, 2005 | 08:19 AM
Ph3n1x's Avatar
Might need new brakes
Old Dec 19, 2005 | 08:29 AM
Greg K's Avatar
it sounds ot me like the proximity switch on the handbrake may be disconnected or out of position. Do the following
open the console and remove the 2 (#2 phillips) screws in the bottom. then the console will lift up from the back. Remove the console and start the car. Cycle the e-brake handle and watch the light. Inspect the switch and see if it is making contact. Lastly check any of the wires abbrasions/damage.
the e-brake is mechanical so low fluid and worn pads won't have anything to do with the parking brake light.
Old Dec 19, 2005 | 09:49 AM
sleet's Avatar
Originally Posted by Dave2
check brake fluid
+1
Old Dec 19, 2005 | 10:09 AM
calvin's Avatar
Originally Posted by sleet
+1
i agree, it's happened to me twice before...add brake fluid to your reservoir and it will go away...
Old Dec 19, 2005 | 10:10 AM
Greg K's Avatar
please just don't add brake fluid. Brake fluid isn't consumed, if the level is decreasing, there is a leak somewhere.
Old Dec 19, 2005 | 10:12 AM
infin|ty's Avatar
I'm going in for an oil change tomorrow so they are going to take a look at it then. I'll let you know what they find.
Old Dec 19, 2005 | 01:08 PM
lancerdealer's Avatar
OR the brake pads are nearly worn out, causing the fluid displacement. If you had a leak you would know it as soon as it developed in the form of no brakes.
Old Dec 19, 2005 | 01:15 PM
Greg K's Avatar
you shouldn't be able to displace enough fluid to bring a warning light on, even with severe pad wear.
Old Dec 19, 2005 | 01:17 PM
Erik@MIL.SPEC's Avatar
+1
Check your pads before you end up needing to get the rotors resurfaced.
I add brake fluid to my Camry one time. ABout 3 weeks later, my ears heard the sweet sounds of metal on metal when coming to a stop. Add 100 bucks to what could have been a simply pad change.
Old Dec 19, 2005 | 03:32 PM
emagdnim8's Avatar
I had the same problem in my wrx.
Pads were worn
After a brake job it went away
Old Dec 19, 2005 | 03:47 PM
el producto's Avatar
Wait did you say the handbrake caused the light to go on because you said you wiggled the handle....
I dont think my car's break light goes on for the handbreak.
Old Dec 19, 2005 | 03:57 PM
emagdnim8's Avatar
/\ the light in the gauge cluster that is on when your hand brake is up
Old Dec 19, 2005 | 04:07 PM
Ryu123's Avatar
check brake fluid
+1. I've seen it on a buddy's car.
