SRS light reset?
Old Dec 21, 2005 | 08:31 PM
Dropspeed's Avatar
SRS light reset?
Anyone know a way to reset the SRS light (besides visiting the dealer) I pulled the gauge cluster fuse when I had the key on (installing gauges) and now the SRS light is on. Apparantly it stores a hard code because it sees a failure with the bulb.
I left the battery disconnected for an hour with no luck...........................Anyone?
Thanks, Matt
Old Dec 21, 2005 | 08:38 PM
mr96gsx408's Avatar
I think you might need to go to the dealer for that. When I removed my airbags and reinstalled them, I had to do that. Hopefully they won't charge. You could always remove the bulb... lol
Old Dec 22, 2005 | 08:11 AM
elhalisf's Avatar
yep, you need to go to the dealer. however, there is a a type of scanner that also reset the airbag system. call around some collision shops, and see if they are willing to do it cheap. the dealer will charge you $80, unless you can make a deal with them.
