Running Rich?
Old Dec 23, 2005 | 06:20 AM
GR3N3RD's Avatar
Running Rich?
edit
Old Dec 23, 2005 | 06:26 AM
Silver05Bullet's Avatar
take it back to the dealer you shouldnt be getting fuel cut at 4000rpm, as a matter of fact u shouldnt be getting any fuel cut if the car is completely stock, check the hoses running of the boost solenoid if you have a boost gauge check what your hitting on it.
Old Dec 23, 2005 | 06:32 AM
get faster's Avatar
That's good advice. Uaually it's modifications that may bring fuel cuts ... ESPECIALLY INTAKES. So whatever you do ... don't go messing with aftermarket intakes till you know exactly what you're doing.
Old Dec 23, 2005 | 06:35 AM
walkedu's Avatar
I'm willing to bet the person that traded it in, took off his MBC and hooked it up wrong. Better be carefull or you'll be needing a new engine VERY soon
Old Dec 23, 2005 | 06:39 AM
Stinkapuss's Avatar
Make sure the maf is plugged in.
Old Dec 24, 2005 | 03:41 AM
GR3N3RD's Avatar
I checked to make sure everything is plugged in and there are no loose hoses or anything, and it's completely stock so no mbc. But i'm taking it into the dealer next week. So hopefully they take care of this pretty quick.
Old Dec 24, 2005 | 04:20 AM
smoothmarine187's Avatar
Veteran: Marine Corp
change out your spark plugs! Thats what my car was doing until I put in new plugs.... NGKBPR7ES or tell them you want NGK 2023 for some reason when I was looking for them....thats the number the auto parts stores went by.
Old Dec 24, 2005 | 04:36 AM
EvoGLH's Avatar
I just had a similar 'gremlin' with identical symptoms:
After checking virtually everything that could be the cause, finally found that #1 plug wire was arcing at the plug boot, and #3 wire was arcing at the coil boot.
Verified by swapping coils & plug wires from a friend's Evo - problem solved!
Dealer is replacing the plug wires under warranty (coils check fine.)
