High flow cat
Old Jan 3, 2006 | 08:00 PM
genrec's Avatar
Just threw in the 3" Ultimate Racing HFC..No CEL, Noticable Power.. I likes!
Old Jan 3, 2006 | 08:04 PM
Jim9925's Avatar
test pipe, some places let you go
Old Jan 4, 2006 | 09:15 PM
Z1 Performance's Avatar
here you go:
http://z1auto.com/prodmore.asp?model...ust&prodid=481
Old Jan 5, 2006 | 04:22 AM
k270kmh's Avatar
model cpsi
helix 200
stock 400~500
SARD 175
Apexi 130
UR ? ? ?
Random ? ? ?
Old Jan 5, 2006 | 04:24 AM
k270kmh's Avatar
btw, Is UR HF a metalic cat?
Old Jan 5, 2006 | 03:09 PM
Evo VIII 4G63's Avatar
well i have the turbo xs turbo back with testpipe which you can also use your stock cat with, so when i get my emissions and inspection done here in PA im just gonna swap out my testpipe with my oem cat.
Old Jan 6, 2006 | 12:07 PM
panem's Avatar
im gonna go for the WORKS HFC. b/c of the dumb CA laws
Old Jan 6, 2006 | 12:13 PM
no the Ultimate Racing is not metal
Yes it is 50 state legal..and the CARB number is stamped on the cat itself
forget about the psi ratings...unless they are all tested on the same machine, it's about as useful as quoting horsepower from one dyno to another
Old Jan 6, 2006 | 12:24 PM
sleet's Avatar
No emissions down here in FL, i've got a cat with the CEL fix.
Old Jan 10, 2006 | 05:10 PM
Rmhaffa04's Avatar
ive got a 3" RNR high flow cat......haven't installed it yet, was wondering if it will bolt up to my factory exhaust?
no emissions in florida, i got the high flow cat, so my car would look factory.
Old Jan 12, 2006 | 09:31 AM
Rmhaffa04's Avatar
does anyone know???
Old Jan 12, 2006 | 09:43 AM
IMR-TIM's Avatar
DC Sports one piece 3" DP w/ cat delete.......ssssshhhhhh don't tell!!!!!!
I used a fouler setup for the 02 and passed NH emiss computer No CEL
There's ways around everything....almost everything
Old Jan 12, 2006 | 02:36 PM
Gruppe-S's Avatar
Hey guys,
I have done a good comparsion on a metal cat vs ceramic. Ceramic will not flow as good as metal and its also more prone to failure over time.
Metal vs Ceramic cats
Thanks,
Tom
Old Jan 12, 2006 | 04:12 PM
strikethree's Avatar
Originally Posted by ashton13
Dude.. dont even spend your money on the high flow out there. Get the ultimate racing test pipe for less.. and be sure to keep your stock cat.
i can "pass" emissions with just a test pipe myself... but, i respect the environment and care about the air that i have to breathe, therefore, i have a hi-flo cat. low emissions plus plenty of power. good trade-off.
oh, and you can get a ticket for not having a cat regardless of your state emissions laws. a cat is required by federal law... and the ticket is not cheap. no that something being illegal is a good reason not to do it.
strike
Old Jan 12, 2006 | 04:18 PM
taenaive's Avatar
UR HFC is good. Recently I switched to the test pipe. and the gain was very minimal. UR HFC do have the high flow. I recommand UR. cheap and serve the purpose. It does rust bit outside on flanges only, but that gives you more stealthy look.
