Which year is mine??
Hey all,
I have searched, but to no avail
I am trying to find out whether my car is an 04 or 05 model... now before everyone starts laughing thinking I don't know what car I drive here's the deal
South Africa mitsu started importing Evo 8 into SA in april 2005. only 40 arrived and even the dealer doesn't knoww if its an 04 or 05 evo, yes SA can be a bit behind sometimes.
here are some engine and model numbers to help
engine 4g63lj4005
model: ct9asngfzr6s
hope that helps. are their any other ways of distinguishing the two? believe there is a difference in the UICP?
Mike
engine 4g63lj4005
model: ct9asngfzr6s
Mike
when i worked at an acura dealership the 8th to last number of the vin number denoted the year
last 8 would look something like this 5A532067 with the 5 before the A signifying that it was a 2005
im not sure if its the same with mitsu or not but thats my 2c
Originally Posted by mrbkkt1
in america, the acd switch would be a dead giveaway.same would be for intercooler sprayer and cupholders. maybe look @ cover of the OWNERS MANUAL?
Ok well mine has the cup holders next to te e-brake and the intercooler spray button just in front of the cup holders. I also Have the ACD button on the dash by the side vent... So I have the 05 model...
It is actually the 8th digit over from the right. So you count forward 8 numbers from the end. That is the UNIVERSAL code. It works for EVERY car manufacturer. You can of course also count over from the left and it would be the 10th digit from there.
5 is 05, 4 is 03, 2 is 02, 1 is 01, z is 00, y is 99, x is 98 and so on and so on.
-Sayajin
-Sayajin
since we are in america, well many of us. i figured you would read left to right, not right to left. and if you open any repair manual, mitchal, chilton, or manufacture's, they explain and break down the vin from left to right, clearly stating that the 8th digit is the engine code and the 10th is the year. complete break down: 1st- country, 2nd- make, 3rd-vehicle type, 5th- restraint, 6th- series, 7th- body type, 8th- engine type, 9th- check digit, 10th- model year, 11th- plant, 12th thru 17th- serial number.
Originally Posted by Sayajin
It is actually the 8th digit over from the right. So you count backwards 8 numbers from the end. That is the UNIVERSAL code. It works for EVERY car that was orginally intended for the U.S. market. You can of course also count over from the left to the right and it would be the 10th digit from there.
5 is 05, 4 is 04, 3 is 03, 2 is 02, 1 is 01, y is 00, X is 99, w is 98, V is 97, T is 96.
-Sayajin, edited by GPTourer
I,O, & Q, are never used and Z, U, and Y are not used as a year designations
