Compresion Test Results!!!! need info....
Old Jan 14, 2006 | 06:45 AM
Chaser27's Avatar
Hey guys we did a compresion test on my evo today and these were the results....
177
170
155
160
that doesnt seem like good news at all, can anyone sugest a route i go with in trying to figure out the problem, im thinking a leakdown is the first thing and then what should i do from there?? thanks so much!
Old Jan 14, 2006 | 06:58 AM
platinumspecv's Avatar
you are good to go man....
Old Jan 14, 2006 | 07:04 AM
xtnct's Avatar
do some google searching... here is a start (found this in 20 secs): https://www.evolutionm.net/forums/ar.../t-154364.html
....snip....
7. Crank the engine with the throttle valve fully open and
measure the compression pressure.
Standard value (at engine speed of 250 r/min): 1,128
kPa (163 psi)
Minimum limit (at engine speed of 250 r/min): 951 kPa
(138 psi)
8. Measure the compression pressure for all the cylinders, and
check that the pressure differences of the cylinders are
below the limit.
Limit: 98 kPa (14 psi)
9. If there is a cylinder with compression or a compression
difference that is outside the limit, pour a small amount of
engine oil through the spark plug hole, and repeat the
operations in steps 6 to 8.
(1) If the compression increases after oil is added, the cause
of the malfunction is a worn or damaged piston ring
and/or cylinder inner surface.
(2) If the compression does not rise after oil is added, the
cause is a burnt or defective valve seat, or pressure is
leaking from the gasket.
....snip.....
Old Jan 14, 2006 | 07:20 AM
Chaser27's Avatar
^ thanks gonna try that!
kajoo
Jun 15, 2016 02:59 PM
EVO261230
Jul 25, 2013 10:01 PM
Markourn
70
Oct 5, 2006 01:48 PM
rocketman
33
Aug 4, 2005 01:20 AM
andenbre
Lancer Engine Tech
76
Mar 16, 2003 07:27 PM
