help what to get for install
Old Jan 14, 2006 | 03:00 PM
Evoshadow's Avatar
Question help what to get for install
ok guys need help i'm going to buy the Injen Intake/IC Pipe Kit and HKS SSQ Blow Off Valve do i need to get any thing else for the bov to install it HKS Bolt On Flange or HKS Electronic Idle Stabilizer help thanks!!!!
Old Jan 14, 2006 | 03:20 PM
kirk@WORKS's Avatar
You may want to explore other owners experiences with using aftermarket intakes on the Evo.
We've had many customers remove their stock intake systems only to cause driveability issues.
(stumbling at over 5000rpms, etc.)
As a result, Mitsubishi Design, Ralliart, WORKS and Cyber Evo only recommend drop-in filters for stock turbo applications.
I'm sure their are many posts about this issue on this forum.
Just looking out,
Old Jan 14, 2006 | 03:26 PM
j8's Avatar
j8
Patience when the car dies at idle. The intake will work great once you get it tuned, but I would pass on the BOV. Get a MR JDM DV and you will be a lot happier in the end. The BOV will cause idling problems no matter what people might tell you. Unless you are running a standalone.
Old Jan 14, 2006 | 03:37 PM
dcvolki's Avatar
Old Jan 14, 2006 | 03:59 PM
hukster00's Avatar
You can always get the Recirculation kit for the hks, or if you planing to vent like it seems I think maftpro running speed density mode be cheapest.
Old Mar 20, 2006 | 05:29 PM
Sosa33's Avatar
So the Injen Intake / IC Pipe Kit is a good kit? cause I been searching about this for the past week. I just want to know if it is worth.
-Sosa-
Old Mar 20, 2006 | 05:41 PM
Eclipsed Evo's Avatar
-Sosa-
Its a good kit as far as I/C pipe kits go as it leaves the battery where it is. Like the other I/C pipe kits its not going to give you much of hp gains. You might want to get an exhaust system before the I/C kit.
f125gpracr
39
Apr 16, 2009 08:15 AM
evilrevo8
Apr 14, 2009 10:10 AM
DCD
Dec 4, 2007 02:08 PM
StreetRicer2010
26
Jul 22, 2006 11:05 PM
fitch
Feb 23, 2005 10:20 PM
