Lower Boost?
Old Jan 16, 2006 | 10:29 AM
Spooldyou's Avatar
Lower Boost?
After installing my INJEN intake setup. i found something odd with my Boost. It would spike to 18ish and settle off at 16 where as before it used to hit 20 than settle at 19. So, I ripped Everything apart and started over again. used all new clamps. and every trick i could think of. Annndd Sur enough SAME THING. SOOOOOOOOO. Is there really that much of a drop when changing the piping and adding an intake? I mean seems alittle wierd to me. Currently runs JUST the stock ECU, no MBC no nothing i took out all my parts cause i had some dealer work to do!
im not looking for advice, Comments. All i wanna know is if this is common or not. Thats all
Old Jan 16, 2006 | 10:30 AM
Ckjeepin's Avatar
It could do to the size of the pipes.. The turbo has to push more air to fill them up. It's like if you get a bigger intercooler there is a bit of pressure drop.
Old Jan 16, 2006 | 10:32 AM
Spooldyou's Avatar
Right, BUT 4 psi drop ? seems alittle high
Old Jan 16, 2006 | 10:34 AM
Ckjeepin's Avatar
Does it feel slower?
Old Jan 16, 2006 | 10:35 AM
matt55's Avatar
have you done a boost leak test
http://www.vfaq.com/mods/ICtester.html
Old Jan 16, 2006 | 10:36 AM
Spooldyou's Avatar
Yup., went to home depot and made that stupid thing with the tube and got nowhere.
mannymartinez's Avatar
get a tune
Old Jan 16, 2006 | 10:38 AM
matt55's Avatar
I would call it stupid its only a tool .
no leaks ?
how high did you test it to ?
stock boost controler ? ----edit recheck to see if the stock bc lines are hooked back up right
Old Jan 16, 2006 | 10:39 AM
DaWorstPlaya's Avatar
Your MAF signals are most likely messed up because of the difference in piping diameter on the intake, thus causing erratic/low boost reading ...
Old Jan 16, 2006 | 10:40 AM
Spooldyou's Avatar
no leaks ?
To my knowledge there are no leaks. But im going to work test it out when i get back
Old Jan 16, 2006 | 10:44 AM
Nez136's Avatar
Originally Posted by DaWorstPlaya
Your MAF signals are most likely messed up because of you difference in piping diameter on the intake, thus causing erratic/low boost reading ...
+1
Your sig shows you use a utec, check your logs and look for inconsistant readings through your MAF (in Hz)
Edit* sorry didn't read the the rest of the post...
AWDTerror
Apr 6, 2010 01:09 PM
zze86
Jul 26, 2007 03:59 PM
NIevo
Apr 16, 2006 10:09 PM
Stop&TurnFreak
Mar 5, 2005 09:21 PM
Stumpy221
Sep 3, 2002 08:09 PM
